soundguy7440
I have officially become a Porty Hack.
I went out and bought a used Nilfisk Advance Aquapro H which seems to work quite well and the heat is better than any portable I've seen. One issue I have is that the vac leaves something to be desired... it isn't terrible and the carpets dry within a few hrs, but I digress. From a cursory look, I should be able to modify the waste tank lid and add a 2" hose barb without much, if any issue. The unit is rated at 150in of lift and 100 CFM, and I am currently running 25ft of 1.5" hose.
Would this upgrade be worth doing?
Thanks in Advance!
Edit: I'm also open to other thoughts on ways to improve the performance! (Excluding throwing it away and getting a Truckmount Lol)
Thanks in Advance!
