Why no demand pumps on SteamAction?
Dwain Ray
Also, there's no demand pump on their 2026 Nike model either.
what gives?
View: https://youtu.be/Y5lMy7ZAPUc?si=9xBBUzDU97Yo8WKm
I haven't watched the video yet, but after studying up on several manufacturers systems and building my own machine i learned that cleanco pto's don't use a transfer pump when transferring water from onboard storage eighter. That's because where most machines need the supply/ water box to be higher than the pressure pump inorder to gravity feed water to it or it will loose prime. And a pressure pump to supply water to the waterbox Its my understanding that cleanco uses a Cat CP5 pressure pump. This pump, insteat of relying on gravity to feed it will suck the water up into the pump eliminating the need for a transfer pump and for that matter a waterbox
Reactions: Giorgio
