no, it's not the same..
Local San Jose cleaner just called me asking about my Aerotech.
He said he doesn't want the new est version because the blower is much smaller..
Lol
He showed this picture to a local supplier and they told him that it's the same as the blower on the Prochem Everest...
25f0f1ee-be0c-4e71-863e-c1a35d8e0fb6
While it could have been ignorance talking, if you are to put a 4.10 next to that 7 series it would look like a shoe box.
Fort Worth , Texas
I do hope they worked out that awful whine they were getting from that new blower at connections in Vegas, the noise my my trucks a walk in the park to work by.
Aero Tech XT
North Salt Lake, UT
Jeremy Wilson
your right Mike, its not the same.
Yes the Helical Tri-lobe blower has a slightly smaller platform, but packs a much bigger punch than the #6 dual lobe. In fact, we are running the new Helical Tri-Lobe at 5% less capacity and still gaining an extra 10% more CFM.
Other added benefits:
  • larger shaft - 1-1/2" vs. 1-3/8"
  • larger bearings
  • less pulsation
here is an example if both blowers were running at max RPMS:
#6 Dual Lobe - Maximum CFM @ 4" HG = 850 CFM
New Helical Tri-Lobe - Maximum CFM @ 4" HG = 1050 CFM
San Francisco, CA.
Hum-- I'm confused--- Why 4"HG as an example? Aren't we running 12-15 HG?
Also the tri-lobe has 3 lobes, which take up more space within the Case/chamber And the 412 has a smaller case then the #6 which I would think means less CFM per revolution.?. Are you operating both blowers at same percentage of max capacity? I would think you are operating the 412 closer to max capacity then the #6.?
Aero Tech XT
North Salt Lake, UT
Jeremy Wilson
I wanted to show examples of maximum CFM between the two blowers. The curve on one blower went down to 2"HG and the other 4"HG, so i used 4"HG as the base line comparison.
The XT's are set at 16" HG
Here is another comparison using 16" HG and maximum RPM's:
#6 Dual Lobe - Maximum CFM @ 16" HG = 725 CFM
New Helical Tri-Lobe - Maximum CFM @ 16" HG = 910 CFM
You can see with these examples the new Helical Tri-Lobe is a larger blower performance wise.
Nope, we are operating the Helical Tri-Lobe at 5% lower capacity then the #6.
Todd Millar
Gainesville, VA
Carpet Solutions
Just curious, Is the new tri lobe blower quieter than the number 6 ?
Also how do your machines compare noise wise to a butler- louder, same or quieter
Boca Raton
Mine is currently 94 decibels which is pretty loud. Sometimes something will seem louder even thou it isn't. Different frequencies seem louder than they really are. Your ears are not a good judge. The difference between 83 and 87 is twice as loud. Your ears will only hear it being a little louder. When you close the back door on my truck it seems quieter even thou the decibel meter doesn't show any real change.
Gene
mirf
New jersey
David Mirfin
can yOTE="Nate The Great, post: 4366832, member: 41924"]What was that?!? I can't here you...........:stir:[/QUOTE]
can you clean that other room for $10.00 cash
Doug Cox
Delavan, WI
Doug Cox
Yeah- The difference between a 45 and a 59 is huge. Can't imagine a 7 series blower size.
