APO for waste tank...
most "low cost" option I know of requires 110vt power supply....AKA, an extension cord
you can plumb in a regular ole sump pump.
If you don't use a an inline filter to strain carpet lint, use a sewage pump
a top quality pump costs around $200-$250.
Mics plumbing and fittings will run around $50 or so
couple/few hours to install
Pump, 1.5" PVC and check valve inside the tank.
Conduit for outside and thru the tank plumbing.
end of conduit gets a 3/4" male pipe thread fitting for garden hose hook up
(use 3/4" commercial garden hose for discharge hose)
Arizona
the water level creates a barrier and the vacuum does not effect them......
Blue Monarch
Lincoln, NE
Dirk Wingrove
Why are they all so damn expensive then? Mine got all wet and the motor died....been without for a coupla years. Would love to build my own, but really don't know how to go about it.
La La Land
BILGE PUMPS...thry're made to be submersible....24/7.........
Blue Monarch
Lincoln, NE
Dirk Wingrove
Somebody could do good by making a foolproof (read, dirk can do it) tutorial on how to make an apo.
Wi
Keith
I have that APO from the unit I bought from Ben make me an offer... I have it ripped apart right now, but I could rebuild it or you could do it yourowndamnself and save some money?
