- Oct 22, 2012
- 28,244
- Name
- Ron Marriott
Not true. It really shows up on thick smart strand carpet.This guy only cleans section8 flat poly carpet
You’re prejudicedRVs can cause soil streaks and if a flood jets gets a pin stream you'll destroy the pile.
and over wet the pad if you is dumb
GooBNot true. It really shows up on thick smart strand carpet.
You idiot
Thanks for sharing... got a number of questions as a newb:I have a 10 and 15” crb, with renovators on both. Renovators are easy on and off. For agitation, whether doing low moisture or hwe, they are awesome. I cleaned 6500 ft by myself yesterday. Crb for pre scrub coffee stains, then Cimexed afterwards. You can do the same with hwe. Crb just glides along. Rotovac is not the same and slow even with brush head.
I am in the process of selling my Rotovacs. I have both the 360i and the 360 XL. Great machine, especially with the brush head but I don't use them often enough. I don't run into trashed carpet that needs it very often. I also have a CRB which use more often when I feel a carpet needs more attention. The Rotovacs hook up to your truck mount and spray and scrub and extract in one motion. Very effective but can be slow making sure you extract well. Most guys use a wand afterwards to extract a little more and get rid of the swirl marks. The CRB is just a scrubber but a very effective one at that. You prespray, scrub, them extract. Works great.
Matt - Thank you so much for taking a look at the items. A few points:Spend a little more money, and get at a minimum an electric sprayer for treating the carpet. In my early years working as an employee, I used a pump up sprayer and it was one of the tools that made me hate this work
The PMF swivel stair tool will give you frustration as well. Save a few dollars and get a non swivel head westpak version. I know the popular guys on here love it, but I hated it because it swiveled too much out of control when I was trying to use it
And you want the black brush version of the carpet rake. The one you posted is too stiff and does a bad job at "grooming" the carpet properly.
If you can find a 40” long in this shape, you’ll like it. It’s my favorite length and shape out of all of them. I used them all and this one cleans the risers great too. Yes you can rotate it without pinching hoses.Matt - Thank you so much for taking a look at the items. A few points:
i.) Noted, and thank you for the heads up! I'll add the Hydro-Force, and maybe keep a pump up as a back up.
ii.) There are 2 version of the Westpak 6" wide (24" wide) and 10" wide (40" long), which do you recommend?
iii.) May be a dumb question, but can I not just rotate the whole wand if I go with the Westpak (or similar)? Or, will it be a hassle and cause issues, such as pressure hose binding?
iv.) Great catch on the carpet rake, and thank you for the heads up! Can you please link the brush you recommend? I don't want to find out I got the wrong one on the job site. LOL
Edit: v.) Thoughts on the linked vacuum, please?
Thanks again!!
Well looks like you're going to get a bunch of different opinions
a rotovac or rx20 is great at cleaning and if you have and use one at every job quality will never be an issue but the drawbacks can be that they are slow and heavy and most guys don't want to use them. I would always follow with a wand after to help pull out more moisture and groom.
the same can be said about the crb I would bet a lot of guys have them and don't use them they sit in their truck and all they do is prespray and wand as fast as they can to get to the next job
Crb price is overkill but like many have said they are good at a lot of things I think for most situations prespray, crb and wand will do a great job I like the 15 inch crb the best the 10 is too small for me.
hit up mikey and buy whatever he sellsAgreed, 10 is too small for me too. I’m looking for a 15” crb that is reliable. Any recommendations?
Mikey, I’ll be happy to do business with you. Can you please let me know which 15 CRB from your site you recommend? Looking for something that can do both carpet and tile.Reminder..
Great info! Thank you so much!! What is an OP?Every new cleaner should have a 175 floor machine..
Scrubbing greasy carpet ( CRBs don't do much to grease, especially on commercial glue down
Scrubbing hard surface
Stripping coatings
Encap/ shampooing with a removable shampoo tank
Stone resurfacing when a weighted driver
Try and find one used locally or online
New they run around a $1000...
1.5 horse
1" head
90#-105# range
CRBs and OPs are lighter, and easier to use and train, but far costlier and not as versatile
I have all three, and carry the 10" and a OP all the time.
The 10" is the best choice for residential work, by far imo.
Works on stair cases, around furniture, can be carried in one hand and takes up less room in your vehicle, you'll want the stock blue, and softer white brushes
Keep in mind, the opinions I express are of a collective, and not just mine...
I'm curious as to why you like the 10" better than 15". Is it only because of stairs? I've personally only used the 15", but my thinking was it would be faster than the 10" and is pretty easy to carry. Should I be looking at 10" for my next CRB?Every new cleaner should have a 175 floor machine..
Stripping coatings
1.5 horse
1" head
90#-105# range
Oscillating Pad machineGreat info! Thank you so much!! What is an OP?
For the hydro force sprayers, is there any that allow you to go easily from 8:1 to 4:1? What’s industry standard for not having to mix yourself? 4:1?Spend a little more money, and get at a minimum an electric sprayer for treating the carpet. In my early years working as an employee, I used a pump up sprayer and it was one of the tools that made me hate this work
If it's that large an area, I'm using a 17" brush or fiber pad under my 175 or OP to scrub in my pre-sprayTell him a 10” crb is not too small if he’s doing residential. If he’s doing a lot lot of wide open commercial areas like me, then 15 is the ticket. Oh, tell him the 10 is awesome around chairs and furniture in commercial as well too![]()
