Swap Briggs for Kohler
N GA
BradFenstermaker
So my Judson TNT is about ready for a new engine.
I have been through 2 Briggs and both a rebuild also.
Currently stock is a 18 hp Vanguard.
Looking at the 22.5 Kohler Command Pro.
Anybody now if the Kohler is significantly larger than the Briggs?
If it's a coupler connection, you need to check the shaft size as well as the physical size of the engine to see if it matches up.
If you're replacing an engine that size...I'd get a Honda. And I'm seeing more Kawasaki engines in the commercial zero turn mowers. I think that's showing some evidence of quality also on those engines
Reactions: BradFenstermaker
I’m glad that’s not blower exhaust blowing crap air on you. Maybe turn it pointing to the left
Oh, I see the separate blower exhaust IS blowing crap air on you. Get another pipe for that also
KevinD
Binghamton,New York
Kevin Dumas
You are going to smell like exhaust fumes every house you go in, in just the time it takes you to start it up and adjust your chem feed and such. I would look for a different route.
