Steve D
- Mar 1, 2019
- 61
- Name
- Steve D'Aquila
I am trying to figure out a way to transport heavy rugs by myself. Any suggestions?
I would appreciate if you took down this post. thank you.
Very Cool. Thank you for the response and information!![]()
Gundlach No. 847 Senior Carpet Cart
The Senior Carpet Carpet solves your carpet and padding moving problems and has an impressive 1,340 lb. load capacity. The full size frame gives the best support for carpet that wants to ‘break over'. Measures 21-1/2" wide x 61" long x 18" high. Weighs 42 lbs. This oversized item will be shipped...www.tools4flooring.com
I like the idea Damon but from the specs it looks like it would struggle with a rug that's over 4' wideI'll be getting a couple of these for my rug shop. It will make it easier to get into the centrifuge.
Are you wanting it for customer p/u & del, or for moving wet rugs around in your plant?I am trying to figure out a way to transport heavy rugs by myself. Any suggestions?
God help me if I ever have to lift a rug that is over 4 feet wide when rolled upI like the idea Damon but from the specs it looks like it would struggle with a rug that's over 4' wide
roro
Go on the internet find out how to fold/bundle rugs and get a hand -truck.I would appreciate if you took down this post. thank you
This is the internet Ron. The premier rug advice site on the internet, I might say.Go on the internet find out how to fold/bundle rugs and get a hand -truck.
Some rug shouldn't be folded.
www.petpeepee.comThis is the internet Ron. The premier rug advice site on the internet, I might say.
I love when he sprays himself with his non toxic product.
Thank you.I'll be getting a couple of these for my rug shop. It will make it easier to get into the centrifuge.
View attachment 92760Toolots, Inc. - Reliable Equipment Fast.
Toolots.com is a one-of-a-kind international B2B online marketplace for factory direct industrial equipment, parts and supplies.www.toolots.com
Customer transport. I usually work alone these days and would like to be able to handle large rugs myself - with equipment of course. thanksAre you wanting it for customer p/u & del, or for moving wet rugs around in your plant?
roro
Is the question about pick up and delivery or moving around a wet rug while processing it in your shop?
I appreciate the response and advice - thank you!Steve, when I used to do rugs, I found it easier to carry a few lengths of PVC pipe in different lengths.
I think they were about 6' & 9' from memory, I don't have any left now.
I would roll the rug onto the pipe, secure it, then I was able to carry it to the van without it sagging.
Of course, bigger & heavier rugs were a two man carry.
Cheers mate.
Agree - thanksA heavy rug needs to be well supported when moved or carried. Sag can damage the rug.
the pvc idea and a kayak dolly
not that I've tried it just an idea
YGTBFKM!This is the internet Ron. The premier rug advice site on the internet, I might say.
good to know it works, now I dont have to try itJeez, you brought back a forgotten memory.
I also had the "Kayak" trolley, it only has two wheels.
Made of sturdy plastic with large wheels, place the rug down towards one end, tie a rope around the other end which allows you to lift the rug off of the ground and lead it back to your van.
Got mine from an adventure store that sells kayaks, mountain gear, tents, etc;
I'm a one man show when it comes to rugs. I limit myself to 9x12's by myself. 10x14 is the biggest rug I do in the shop. If I can some help getting it into my van, I'm good at getting it from the van to the shop. I've used hand trucks and flat Dolly's time to time. I like the idea of the kayak dolly. I have one here, I'll have to take a look at that. When I know it's a heavy rug, I ask them to have help there otherwise, I have to pay a second person and add it to the costTransporting heavy rugs is a two man job. If your working solo I’d figure a way to clean them onsite. If they can’t be cleaned onsite then get some help for the transfer. You don’t need to look like an idiot wrestling a rug in front of a customer.
