Somebody brought one to MF. I tried it.
No thanks.
too slow?
Or not effective??
or both?
.L.T.A.
at those temps most everything is vaporized.. but keep a shop vac and towels close by. Some showers TM is better but we do a lot that are just needing a good steam clean, so not occupying the TM and slowing the whole job down is pretty profitable.Bjorn, How does that unit you speak of work on natural stone shower floors with the soap scum/ foot oil soil circles.
Does it have enough "flow" to rinse the contamination to the drain, or do you have to wipe it with towel?
doesnt sound like the best unit tbh. Heres a great one. Very compact and continuous fill, heats up quick.Way to slow, takes up too much room in the truck and the time needed to generate another batch of steam between cleanings is ridiculously slow and far too often
Way to slow
Stephen, that’s the classic soil circle... was that straight steam or chems then steam? Awesome pics...
Vaporize? As into the air I am breathing?
Steambrite will make you an adapter that allows you to plug a 220-240 volt machine into 2 separate 110-120 volt outlets. Has a circuit indicator to let you know that you are on separate circuits.
No different than plugging in a 2 cord machine. Mytee easy.Next you'll be recommending a Mytee built Smoke Alarm...
sb 120 combiner and a mytee smoke alarm?And that was caused by?
for some reason your picture doesn't show up on my computer, just on my cell phone. I assume that was Steambrites warehouse that burn't down?sb 120 combiner and a mytee smoke alarm?
