My 2002 white magic
You work with your wife?
Not always but often.
She cleans a lot of the apartments I clean the carpets for and the new construction. I also fill in when someone calls off.
I am the one who trained her too.
The WM wouldn't start yesterday after a job. I felt like an idiot in front of the customer. Looks like the battery clamps weren't tight enough. May need another new battery now. This one is 3 years old but the alternator was bad for a long time.
Why did you shut it off?
I always shut down to wrap up and get paid.
I think I need to shim the contacts on the side post. The nuts tight but I have to pull the wire harness to tighten things up. Another washer should do the trick. Ill try and remember that next time it acts up.
I shut it off at lunch and end of day. Only 3 or 4 minutes to wrap up with two on truck.
I'm not that good.
With two on the truck I go for the check while my guy wraps up. Customers talk for over 5 minutes while fumbling around looking for the check book and asking questions.
I'm not that good.
Lee just tells them shut the f...k up and give my money. My truck is still running.
Had my blower belts break with 5 stairs left on the job yesterday. Fortunately I had the old belts and it took 10 maybe 15 minutes to get it back running.
First time I had them break. Been on over 2 years. Time to replace them all I suppose. The engine belts have been squilling on humid days.
