cds 4.8 just shuts off
Derrick M
Derrick M
Hello. Im having a issue here. Got hydramaster cds 4.8. it runs great, you can clean for hour straight until it cuts off or you turn the cds off. Then it just revs the engine up when you try and restart the cds. Its in a 2013 chevy express no engine problem no engine codes.
all lights on throttle box are solid
lube is up to date
all filters cleaned
checked all grounds
Salsa unit is functioning properly
no metal shavings around clutch
new belt and pulleys
traced all wires to make sure intact.
Is there anything im missing here? thanks
Probably a sensor in waste tank, water box or overheat sensor.
My waste tank shut off level went bad in my cleanco and it would shut off. I just disconnected it.
Brad Gouveia
like everyone says sounds like waste tank shut off is messing up some how. I would disconnect it and see what happens.
Matthew Sturgis
Is the CDS shutting off completely or just slowing down to 600ish rpm?
Mine will drop into safety mode randomly sometimes. If it was the waste tank sensor than your light should be on. That's weird that it will rev the engine but not engage the machine. Do you lube your blower at the end of everyday?
Scott Turknett
Mine too goes into safe mode quite a bit. Yes, the blower is lubed daily.
My best guess on this one is that the clutch is failing.
lube is up to date
all filters cleaned
checked all grounds
My butler has been doing this. I figured it was because it sits a lot right now. My WM did it a lot too until I replaced the clutch.
I think its the magnetic switch in the clutch. It just doesn't engage the clutch so everything else works the way it should. Like revving the engine.
