Part number Vortex 777 blower belts 2000
AJR
Whatshisbutt
I need to replace my belts on my blower. I am not sure if the ones on there now are the correct ones. can some one post the correct part number or brand.
Erik
Erik
Headed to the shop. Call me after 10:00, ill have that for you (734)771-2312.
Reactions: GCCLee
G
GCCLee
That is Awesome Eric
Pretty Sweet to see ya diving in to help a brotha out : )
Erik
Erik
Going anyway. My Wife filed away everything for last year, and have no idea where to look. Not looking forward to the day -2 windchill-15 now. When will it end? :hopeless:
Erik
Erik
Found them.
Royal Supply Co.
1209 Lowell St.
Elyria, OH 44035
(440)322-9090
www.royalsupply.com
6008
3 5VX800 - Gates 5VX800 Super HC Molded Notch V-Belt 94140800 Blower.
2 AX54 - Gates AX54 Tri-Power V-Belt 90122054 Pump.
Total $124.94
777
3 5VW750 - Gates 5VX750 Super HC Molded Notch v-Belt 94140750 Blower.
2 A48 - Gates A48 Hi-Power 11 v-Belt 90022048 Pump.
Total $114.88
these are the best prices I could find.
Reactions: AshleyMckendree
AJR
Whatshisbutt
So my 777 uses 5vw750? I found the 5vw800 local will those work on 777?
AJR
Whatshisbutt
The specs for the 5vx750 lists 75" and the 5vx800 as 80" will that still work
D
dgardner
I'm not sure I understand your question. Eric listed an '800, the Vortex manual listed an '800, you said you had found the '800's locally - seems like that would be the one to use?
Erik
Erik
I took the cover off. the belts are 5VW750.
AJR
Whatshisbutt
Thanks. You have all been a great help.
So the the size is 5vx750 what would be the best brand and style belt then?
AJR
Whatshisbutt
picked up some 5vX750 they worked out fine they're both right on. Got the super gates 80v
Reactions: dgardner
