Fan clutch
glenboy
GLEN
Just discovered my fan clutch squeaking on my 02 GMC im wondering Auto Zone or Dealership....im trying to avoid the helicopter noise from a aftermarket fan clutch...I know dealer means more but quality as well....
Sent from my SAMSUNG-SM-N900A using Tapatalk
Dale Compton
I put one on my '01 Chevy from NAPA last year, so far so good. WARNING: If that is still the factory clutch it will probably be tough to get off. I had to use about a 4' cheater bar and a great big pipe wrench to get mine off. Good luck.
glenboy
GLEN
Does it make alot of noise all the time.or just on start up
Is yours out? Have you used the card board to try to stop fan?
glenboy
GLEN
No I have a job in the AM.then after that I will pick up a new one ..what do yo mean card board to stop fan??
You fold up some cardboard and stick it into the fan blade path and see if you can stop the blade or slow it down. If it slows down or stops it is bad, if not it is still functioning as designed.
unless it is locked up...THEN
you get the helicopter noise .....
glenboy
GLEN
Im doing 1 job in romeo and replace....do u recommend the heavy duty or reg
well i put a $50 one on about two years ago (it was locked tight)....
now i could stop it with my fingers....(don't try this)....
so it's kinna lik a crap shoot....
