Scott Rogers
- Oct 7, 2006
- 1,033
After 10 years of hard, mostly trouble free, work. Shes starting to look tired. Still running good but couldnt see sticking it into a new van like this.
Uploaded with ImageShack.us
Designed a new frame. Built a prototype out of wood and took it to a fabricator, told him to copy it using. 1/4" plate on 1/4" 1.5 tube (top rails) 3/16" tube everywhere else and 1/4" aluminum face plate.
primary concerns.
1. large enough to fit bigger blower and engine when time comes
2. ability to mount virtually any type of pump
3. pump and plumbing must fit completely inside the frame 100% of the time (no pump hanging unprotected off the side of the frame)
4. everything easily accessible.
5. engine mounted on slide plate to make easy belt and coupler changes.
turned out great and rock solid
And here she is put together. pretty much the only original thing left though is the blower and the heater.
I can pull the engine in under 5 minutes.
coupler change under 5.
Belt change takes under 7
pull pressure pump or dump pump in under 10.
pull electric vac reel in 3 minutes
pull fill and dump reel in 3 min
Quick and easy set ups and wrap ups at the job site.
Plenty of room in the front for what ever is needed.
Big OP, electric sprayer and whitaker CBM, spare wand fit in the shelf along with 12 gallons of chemicals.
And still plenty of room for my M5 of 2 more Big OPs or what ever.
Still have quite a bit to do, but its getting there.
primary concerns.
