Seamer Down Now
Do you own/use a SDN?
  • Yes, every job without fail.
    Votes: 0 0.0%
  • Total voters
    5
Jack May
That Kiwi
Palmerston North, New Zealand
John
Do you use the SDN?
Why/why not? experiences?
Personally, I've not had mine that long but use it on every repair job I do and LOVE the results. It flatens everything immediatelys and holds it that way!!
John
Jack May
That Kiwi
John
One thing I found when using the KoolGlide for repair work is giving the tape sufficient cool down time before overlaps like corners or tape running side by side.
If you hit it too soon, it'd actually burn the tape from over heating.
With the SDN, that is a thing of the past. 20-30 seconds and the tape is cool enough to move to the next section without fear of overheating and causing burning which on a light weight olefin carpet can cause burn damage... I know coz I've had to re do a repair larger than before :oops:
Also helps eliminate peaking of seams and repairs.
John
Harry Myers
Charlotte, NC
Harry Myers
I like to use it on seams with patterns that run off. Instead of stay nailing it , I spot weld it with the kool glide. Than use the SDN for a quick dry time. With out the nails.
