Auction Rotovac 360i Auction w/ 3 Port Carpet Brushhead and Sheardry Upholstery Tool
Rick J
Ohio
rick Jones
So, are ALL the trucks now so equipped??:biggrin:
FWIW, and not that it matters, I still use my original two head RV. When I got it many po pooed it . Work was it used too much H2O.
Using it mainly on really nasties, I found I could actually use less H2O. No need to hold the trigger open. Using it with a porty. Like I said , not that it matters since yours is paired with the truck.
But I put the prespray down heavy through the unit, with no vac where needed, for agitation. then when extracting , let the vac, and agitation do most of the work, just bumping the trigger.
I was bidding on this as well. by the way. Congrats.
Reactions: CJ-FL
I was hoping to do that much carpet cleaning part time next year. Do you clean everyday Steve?
No. Not even close. Some days are hell though and those days off are for recuperating.
This year has started real slow for residential due to all the rain and cold. Commercial is where it's at. Just crappy hours.
Rentals are a huge market here. I don't count those as residential.
Just unboxed 10 minutes ago
RE in..
Wand out..
Do you set up and prep, hit the bad areas with it at 300 psi. Watch the tube as well as the carpet, you'll know when to move on. Don't hover over seams. Perform a quick dry stroke.
Hook up your wand and clean the clean areas and give the RE'd areas another dry stroke
I use full speed 98% of the time but some say slower dries better, which may help in the Swamp
