Victoria H
- Joined
- Nov 21, 2023
- Messages
- 43
- Name
- Victoria Heaberlin
Auction includes:
Odorcide® Smoke Brake works, and it’s easy to use. Designed for the worst tobacco AND marijuana odors. Odorcide® Smoke Brake is a Professional Strength Odor Eliminator that eliminates smoke odors from carpet, upholstery, walls, cars & more. Works best with a pump-up fine mist sprayer or fogger. Odorcide® Smoke Break has a pleasant fragrance that dissipates as it dries. Gallon concentrate makes 32 gallons at full strength.
Odorcide Pro Renewal is the same formula as Odorcide Fire & Flood, but with a brand new name and look! Odorcide Pro Renewal Odor Eliminator – Professional Strength Concentrate – Eliminates mold, mildew & smoke odors from carpets, clothing, walls, drapery, and upholstery. Anywhere the odor is located. Safe for use on any surface. Works in conjunction with antimicrobials if mold spores are present. Works best with a pump-up or handheld sprayer or garden hose applicator. Dilute with regular tap water, pump up the tank and apply. Then let air dry. That’s it. Odorcide Pro Renewal has a pleasant fragrance that dissipates as it dries. Gallon Concentrate makes 32 gallons at full strength.
- 1 Case (4x1 Gallons) Odorcide Smoke Brake
- 1 Case (4X1 Gallons) Pro Renewal
- Free shipping to lower 48 (only)
Retail value $440+
Starting bid $250.00
Minimum bid increment $10
Auction ends Thursday July 18 at 9PM EST/ 6PM PST
