White Collar said:
Meat... What is max and where do I get it? I had a repo I did today and I used flex, did pretty well but it still left some spots.
Sorry if i wasn't clear, WC.
"max" is two scoops per gal of
Prochem Powerburst.
Powerburst is a powder and comes with a scoop.
For the rat nazdies, we use 3 scoops pr gal (max and 1/2 mix ratio)
more often than not, those are "heaping" scoops
you can find Prochem Powerburst at any disty that sells PC chems.
Mix it with hot water and don't be afraid to spray it on heavy.
On some of the restoration/savage rags we see in sec 8 rentals, it's not uncommon for us to NUKE it at a gal per 100-150sf
at that rate, you can hose down the whole joint and not worry about it drying out before you get there.
By the time we get to the living room (which is generally the last and dirtiest room) the juice has been dwelling for 30 minutes or more.
The longer the dwell time, the better.
if your local disty doesn't carry PC chems, but has Bridgepoint chems, try Power Break.
It's a "hammer" too. I'd say it works just as well as PBurst
My only knock on Power break, is the unpleasant odor while it dwells.
That's why we don't use it, but it will indeed kick a rat nazdie's azz
..l.T.A.
