E
Eric
kmdineen said:Eric said:Hi, That is a very good point and Jonathan Young at Xactimate told Ken Horvath, the inventor of the ELE that the eTes, Firebird and the ELE 6400 will be all categorized the same and charged the same rate at $230/day. The code he gave Ken is WTRHTAM>. Ken Horvath is calling Xactimate tomorrow to find out why it shows that way. I charge $230/day and the reality is the ELE 6400 outperforms the eTes. The eTes uses high air flow (air mover) which reduces the temperature rise. The ELE uses 275 cfm which will give you about 25 degree temperature rise/circuit. You then use your are movers to distribute the heated air throughout the drying area and a downdraft fan to bring the heat back down to the flooring. (Vortex type drying + heat) I sold a ELE 6400 to a company in Kentucky that had eTes.s and in their own words the eTes doesn't even come close to performing as well as the ELE 6400. The ELE 6400 thermostaticy controlled and the eTes is not. The ELE 6400 is NEC ® compliant (National Electrical Code), the eTes is not. Not having a thermostat could become a big problem. With the eTes if you were to restrict the air flow, which does happen when the eTes is hooked up to a wall drying system you could have over heating problem. I fill safer using the ELE 6400.kmdineen said:Thanks Eric, the ELE 6400 seems like a handy piece of equipment to have in the tool box. Xactimate lists the E TES at $205 per day, with the necessary air mover at $25 per day bringing the total daily rental for the E TES to $230 per day. The ELE 6400 lists at $170 per day with a built in air mover. Assuming the performance of these two systems are similar why would I buy the ELE 6400 when I could get $60 per day more in rental charges for the E TES?
Eric
Color Tech Restoration
http{//www.colortechrestoration.com/
Oops! It must have been an old link to your web site http://www.thermalenergydryingsystem.co ... age486.htm that said $170 per day for the ELE .6400 The xactimate code is the same as the E TES and Firebird.
How does the ELE 6400 compare to the Firebird?
Hi, I think the Firebird is a great system. The big difference it the Firebird is it requires 230vac. The ELE 6400 is 115vac. The ELE comes with a thermostat and the Firebird you must buy the thermostat separate and install the thermostat yourself. Physical size, you can put 4 ELE 6400’s in the same area as 2 Firebirds. This can become very important if you have limited space in you van.
My personal choice is the ELE because I do work in many older mountain homes that in many cases don't have 230vac.
Thank you,
Eric
Color Tech Restoration, LLC
Evergreen Colorado
http://www.colortechrestoration.com
