Dependable work horse portable
Who makes a dependable, durable, two 3-stage motors portable extractor?
I do not need more then 200 psi. No need for heat.
An indicator that you are using the same circuit a plus. Small foot print a great plus (these damn small vans.) Large wheels to climb stairs a plus. Less weight is definitely a plus. Oh yes and since we live in a perfect world it will be nice if it does not cost an arm and a leg.
Any advise gained from personal sweaty experience will be highly appreciated.
Thanks in advance.
Ofer
dependable workhorse portable
Is any one familiar with Powerflite BLACKMAX?
diamond brian
The Mytee Speedster is probably as reliable as they come. It is also available in just about any combination of pumps and vacs.
kolfer1;
I would wonder why you don't want more "pump power". Something closer to a TM pump ability.
With two 3-stage vacs, you can use more GPM & pressure to flush the carpet.
We like 1.6 GPM for a portable with dual 3-stage vacs.
Hi Larry:
I forgot:
Which of your portables has the AC motors? I think the Breeze has the Lamb motors and what is the disadvantage?
How does it compare to the Olympus M3-200.
Thanks
Ofer
E
Ed Hartman
I would try to get something from a local distributor, that way if you run into problems you can take it to them.
Ofer;
Both the Breeze 450 PSI & the Century 400 PSI use AC motors for the pump system.
No motor brushes to worry about, and higher efficiency.
The Breeze has Lamb Hi-Perf 3-stages.
Olympus is a good machine, but we had some difficulty with cooling the vac motors.
Thanks in advance.
Ofer
The Olympus M3-200 (by Hydroforce) would meet your specs of two 3 stage vacs, large rear wheels and an indicator to let you know if you are on two circuits. Foot print is average.
I agree with Larry that there might be jobs that would benefit from a larger pump and /or heat. But you could use a bucket heater.
I am sure there is a distributor with-in a reason distance that carries these.
Scott Warrington
Brian L
Brian L
Olfer,
Send me a pm. I have a Speedster I don't mind parting with.
