Daily ritual
Bob Foster
Your tired from a busy day of work and you pull in your driveway. You think this won't take long to do and you go about getting your truck ready for that late night emergency call or tomorrows appointments.
So you dump your waste tank and fill up your water and go home. There I'm done because I know I got lots of pre-spray on board.
or
do you do it properly?
Dump waste tank
Clean filter
Fill water tank
Add clean wiping rags and remove the dirty ones
Check block and tab stock
Clean out vacuum cleaner
Clean out junk out of front of truck
Wash truck if dirty
Check truckmount oil level
I bet I missed a bunch so what's on your daily list?
How about what's on your weekly list?
Lube blower and other zerks
Check belts
Rinse waste tank
Check all spotting stock
Wash floor of truck including in cab
joe harper
florida
joe harper
ALL OF THE ABOVE........EVERYDAY FOR AT LEAST LAST 20 YEARS..........
Is there a reason why the waste tanks are not rinsed at the end of EVERYDAY :?: :?:
Seriously :!:
Arizona
or
Dump waste tank ...Yes
Clean filter..don't have to every day
Fill water tank...Yes
Add clean wiping rags and remove the dirty ones...Yes
Check block and tab stock....Yes
Clean out vacuum cleaner.....Yes
Clean out junk out of front of truck......Empty trash can on the floor
Wash truck if dirty....No
Check truckmount oil level...No
Lube blower and other zerks...Every 50 machine hours
Check belts..same as above
Rinse waste tank....once a week....
Check all spotting stock...Yes..
bob vawter
Grassy Knoller
La La Land
bob vawter
Seriously :!:
i rinse mine about every SEVEN YEARS.....i can tell when it's due cuz the coins get about two inches deep and affects the dump..........
OHH...that's right you guys don't get coins in yor waste tank...right?
joe harper
florida
joe harper
NICE...Bawb :shock: :shock: :shock: :shock:
The little ladys in the hood.... Probably just think it is the chitlins or the turnip greens
on the stove :wink:
Able 1
Wi
Keith
The filling up at the end of the day is one thing I try not to do... Why put all that weight on your van overnight? I know all 3 of you guys have box trucks but for a van I really don't like the idea.
Chris A
OH
Chris
Doesn't really matter water tanks are gonna kill the van one way or another.
