100% VLM ???
SteamwayPro
George
Oh No now I got a Cat Odor job next Sunday
After doing that dog pet odor job on Friday I got a call from her friend that has cat odor
She says no pet stains are visible but she can smell something
She keeps the cat box in that Bedroom
Cat odor is much worse than dog odor and I made no promises
I'm considering using Odorcide Cat Attack but will probably use Just Gone
I've had Cat Attack for a few years but never used it
LESS water MORE agitation !!!
Reactions: frank fratto
SteamwayPro
George
Yes Sunday. I work Saturday and Sunday if needed
And her husband works Monday to Saturday. She wants her husband to be home
Frank Fratto, get on here and tell me what's not true. Join the conversation. Do most encaps not leave residential carpet with a crunchy feel. It's supposed to crystallize if it's a good encap.
Reactions: Living The Dream
jessi
Jessi Lopez
I’d use acid
SteamwayPro
George
I’d use acid
I have Magic Wands Crystal Rinse that I have used for many years
I use it a few times a year to flush out bad stains and pet stains with my portable
I won't know until I get there and see for myself what the odor is
This is going to be a PP 5000 UV Light searching for urine job
She said no visible pet stains
When you post others are dinosaurs and don't understand because your way is best!
That's a fight when others have in deed tried and thought about it.
And it wasn't a good fit.
He who eats meat compared to him who only eats vegetables.
Be fully convinced in what you do.
That's fine, making it a sin for everyone who doesn't agree not so right.
SteamwayPro
George
I don't consider it a sin to HWE
It's just the Old Fashioned Way 😍
But if you use the HWE Method and get carpets dry in 2-5 hours. Great !!!
I just prefer a more profitable and simpler way to clean carpet, with 1-2 hour dry times
frank fratto
frank fratto
Thanks for the invite. I prefer not to argue with anyone. A little bit of my carpet cleaning history, 45 years of owning my own company (yes, I'm old), still working everyday, 40 years being in Salt Lake City, Utah and 5 years in the Orlando area. I have owned multiple HydraMasters prochem, multiple Steam Genies, and 2 homemade fire breathing dragons. I agree, truck mount steam cleaning works but when I switched over 10 years ago to VLM, carpet cleaning became fun again, profitable, and 98% of customers did not care. I am convinced that any method, done properly, with enough time, chemical, agitation (heat from friction), and with the help of hydrogen peroxide and good quality chemicals, you should be able to get a simple 1" thread of carpet fiber clean. To respect of all the cleaners on this thread, I'm sure you all try to do your very best. I know I take pride in my work and I'm sure that all of you do too. Good luck to you all and God bless. -Frank
I respect that. Can't agree more. However, I still know residential carpet, poly and nylon is gonna have that crunchy feel when you walk on it barefoot. Do you #warn your customers beforehand or just ignore it and hope they won't notice. Just sayn Welcome Frank!
frank fratto
frank fratto
Hi Kenny, when enough peroxide is used, the carpet is actually softer after it dries and is residue free. That has been my experience after using it for the past 10 years. The trick is hydrogen peroxide. I've walked on many a carpet hours and days after it has been cleaned, felt it with my hands (and barefoot in my own house, my family's house and my neighbors' houses) and I have been back in homes weeks and months later to clean something else, and trust me when I say, the carpet has never stayed cleaner or residue free then when this method is used. I easily can afford to buy myself a truck mount if I ever choose to do so again. I doubt that I ever will. This method, in my opinion, is the cat's meow for me.
Honestly using a product like carbonated cleaning solutions stuff doesn't leave it crunchy, but olefin and polys love oil so it might not be strong enough.
If I was to vlm Residential I would use it.
I would pre vac pre spot, pre spray, crb agitate,
Orbital extract and post groom with crb or rake.
But that's a lot of steps to make it something I would consider.
Unlike a guy named Nate in Portland a few years ago run in pre spray encap pad over with a oreck, then post crb to groom.
That's cheese
Reactions: jessi
Of the Release It products only Hydrox has the peroxide in it. I use it A LOT and it's really good, but not so much for residential. Yes, I've used it in my house and that's why I'm aware. I've used crb,
Vibe, the whole nine yards.
Swani
That's cheese
He had a crazy high minimum, but the way he structured it was interesting. That minimum basically covered most of the home, multiple rooms instead of just a couple, and you could also add upholstery as an “area” under that minimum (like a sofa counting as one area, a loveseat as another, etc.).
frank fratto
frank fratto
I've never used Release It, I'm sure its a fine product. My go to is Carpet Details and peroxide. And if I need to bump it with multiple choices of chemicals, depending on the situation. Zero residue problems and always a soft hand to the carpet.
SteamwayPro
George
Are you adding peroxide to Carpet Details
How many ounces
It was my favorite for VLM for a few years but switched more to VacAway in 2023
So your using Carpet Details at 4 oz plus peroxide ?
SteamwayPro
George
Hydrox can leave carpet stiff if you put down too much
I often go back and check on carpet I clean at my Apt Complex
I checked a Hydrox job and it wasn't stiff. It looked beautiful after drying
I bring soft water to every job and CRB carpet after cleaning to groom maybe that helps I don't know but I don't see stiff carpet if you don't use too much
I only use Hydrox on lightly soiled carpet so I don't need to put it down heavy
frank fratto
frank fratto
I can't say I've learned a lot from this thread, but my big question is: what's the best way to clean my pads when I'm done cleaning? Do I just vacuum them off or throw them in the wash machine?
If you're going to VLM? You need to learn how to maintain and clean your pads It's like any other piece of equipment you own.
If they're residential pads, trash em😉 If they're commercial pads, wash em😀
