100% VLM ???
SteamwayPro
George
George,
What is your process for removing candle wax?
I use a Namco Steamer to heat up and soften up and loosen the wax. Then use a drill brush or scraper to scrap wax off carpet
Never a problem getting wax off carpet but sometimes the red stain from red wax can be a problem
Need to use red stain remover for that but sometimes still very difficult to get the red out
I also have a Wagner Wall Paper Steamer, that can be used on wax or red stains, but it never gets out of my basement
Only problem with Namco Steamer is they don't last. They usually stop working after 2-3 years and yes I use distilled water in them
That is a picture of Namco Steamer removing Red Stains
frank fratto
frank fratto
Obviously you haven't run a cimex. I wouldn't run in residential, so it probably wouldn't be beneficial for you. It is the king of agitation!
Cimex.
I have, I've never owned one. { it was very efficient]
50% of commercial it would work well.
The 175 will not break down.
you can use it in tight areas
you can use it in open areas.
use it in homes
you can carry it
Plus, i'm a pad man [commercial or house Pads all the way!]
frank fratto
frank fratto
I love that steamer
