Bane Wand Flow questions
I got a guy using a bane set up with it's OEM 3 jet wand w/ 6 flow (11002 X's 2) and he wants to get a Chosen Wand which comes with a stock 4 low set up (9502)
Because the bane system relies on low pressure(he runs 180 psi) and high('er) flow, should I set his wand up with two 9503's?
All my truckmount guys love the Chosen's 4 flow as it gets the same results as 6 flow wands wit less water (faster drying!) and I only tweak the flow for small porty guys with 2 or 3 flow total...
Thoughts?
Dwain Ray
Tried to find the answer for you no google but after asking the exact same question 4 times and getting 3 different answer. I deleted the information. I can send you a standard spraying systems flow chart and the math to modify the psi if youd like. Or go with what Google tells you i asked " what's the flow rate of a 11002 vee-jet @ 180psi spraying water" when i add spraying water the answer was the same twice
Thoughts?
I would stick with the six flow. With the lack of pressure, he needs more flow to flush the carpet. I like the 4 flow but I am using 350-400 psi on the portable and 500 psi on the truck. I have an old portable with a 150 PSi pump and the 4 flow on it sucks.
Good point!
