Up for Auction:
Saiger’s Sauce Code Red features the same great formula of original Saiger’s Sauce 1 plus an added oxidizer and enzyme to power through the toughest, greasiest, grimiest soils you can find.
Stable Oxy and Enzyme Combination
Code Red relies on a high-performing oxidizer plus a fast-acting protein enzyme to digest oily deposits and organic soils. It breaks down thick, sticky binders that hold onto dirt and soiling, emulsifying them for easy rinsing. With other enzyme-based formulations, the addition of an oxidizer and heat will destroy the enzymes and render the product ineffective. But Code Red’s enzyme is not sensitive to heat or harmed by oxy, allowing you to get the power of both agents in a single formula. Code Red was designed for cold water efficiency and effectiveness, so it's great for smaller truck mounts and portables. (Though it performs well and works even faster with heat!)
Note: Once mixed, Code Red doesn't have as long of a shelf life as other Saiger's Sauce products. We recommend using up your mixed batch the same day for best results.
Your Go-To Product for the Toughest Carpet Cleaning Jobs
Code Red was designed specifically to tackle the worst of the worst—trashed rental carpets, severely neglected residential carpet, and greasy, grimy restaurants. You’ll love how Code Red performs in the main eating area of a restaurant, but where it really shines is on that first bit of carpet right outside the kitchen. You know the part we’re talking about—that small section that absorbs most of the grease and oil from the bottoms of the wait staff’s shoes as they exit the kitchen. The area with black grease so thick, you could scrape it up with a business card.
Code Red goes to work right away, liquefying those thick, gunky deposits for easy and thorough removal. It rinses freely and won't leave behind any sticky residues. You’ll be amazed at the results—and your customer will be thrilled!
Fragrance-Free so You Can Add Your Favorite Deodorizer
Code Red contains no perfumes or added fragrances, making it a great product to use around individuals who may be sensitive to strong scents. And since it is completely fragrance-free, you can add in your favorite deodorizer and leave your customer with clean carpet that smells great, too.
No Harsh Additives
Saiger’s Sauce Code Red is free of harsh additives that can irritate users and building occupants.
Code Red contains ZERO of the following:
Developed by Saiger's Steam Clean, a family owned and operated cleaning company employing four generations of cleaning specialists, Saiger's Sauce Code Red is the newest product in Saiger’s line of high-quality carpet cleaning technology.
Saiger’s Deep Blue is a versatile rinse agent that neutralizes cleaning residues while providing deep-down cleaning and conditioning that leaves carpet with a bright look and soft feel your customers will love.
Give Your Cleaning a Boost
Deep Blue is an acidic-to-neutral rinse (depending on mixing ratios) that complements the cleaning power of your alkaline pre-spray. It neutralizes cleaning residues, but also provides an added boost of cleaning power to remove dirt and soiling.
It delivers terrific results on dirty restaurant or commercial jobs, plus it even helps remove urine salt deposits for more effective pet urine treatment.
Enhances the Look and Feel of Carpet
Deep Blue acts as a conditioning agent that stabilizes and brings out the colors of acid dyes in carpet, making them look brighter and more beautiful. It inhibits browning and color-bleeding.
It also enhances the texture of carpet, giving it a soft and fluffy feel your customers will love.
Speeds up Cleaning Time
Not only does Deep Blue deliver outstanding cleaning results, but it also helps speed up your overall cleaning time. Dirt and soiling release faster and easier, so you need fewer wand strokes to get carpet clean. Carpets are left cleaner and drier, which speeds up your overall job time.
Safe on All Fiber Types
Deep Blue can be used on all fiber types, from stain-resistant residential carpet to wool and other fine fabrics.
Safe on All Equipment
Unlike other rinse agents that can corrode your equipment and affect your solution lines, Deep Blue is not so acidic that it will have a negative effect on your equipment. Use it with confidence day in and day out.
Part of a Family of Cleaning Products
Developed by Saiger's Steam Clean, a family owned and operated cleaning company employing four generations of cleaning specialists, Deep Blue All Purpose All Fiber Rinse is the newest product in Saiger’s line of high-quality carpet cleaning technology.
Total package value with Free shipping to the lower 48 States $302.12
Starting bid $190
Minimum bid increment $2
Auction ends Wednesday May 18th at 9PM EST/ 6PM PST
- One 4 x 6.5 pound CASE of Saiger's Code Red. "Release the Beast"! Retail Value $204.10
- One 4 x 1 gallon CASE of Saiger's Deep Blue All Purpose - All Fiber Rinse "Take Your Cleaning to New Depths"! Retail Value $98.02
- Free shipping to lower 48
No Harsh Additives
- Butyls
- D-limonene
- NTA
- Solvents
- Fragrance
Starting bid $190
