- Oct 6, 2006
- 117,313
lol, you probably didnt have the skidder under the bonnet that covered up 60% of the cotton surfaceI used one of Geurkink's old blue machines that needed to be kick started every time cuz it was so underpowered. How did he use that POS for so many years? Worked okay, though. Worked much better with a motor upgrade. Memories. Yeah, we constantly upgraded our low moisture system until we got the WGCCM--PHX!
Used that, too!lol, you probably didnt have the skidder under the bonnet that covered up 60% of the cotton surface
Jeff was kind enough to show Dan & I what he was doing with low moisture. It helped greatly to not just read about it but experience it.I started in the early 80s. Although I had done a fair amount of bonnet cleaning over the years with limited success the first time I saw the Cimex was in St Louis at a Summerfest. I had been reading about it on the boards and when I first saw it in action, I was not impressed at all. It was the only Cimex I’ve ever seen without a tank and they were using brushes. The next time I saw it I can’t remember but I think it was in Florida, I bought it on the spot. Thanks to Rick Gelinas. It’s been my main cleaning method for the last 20 years or so.
Who's hype?I believed the hype about encap with it.
That’s the one....7000sq/ft an hours was floating around associated with a CRB.![]()
This was back in 2014, 2 years before I was here...Who's hype?
not mine.
Opposite
My father had been cleaning with bonnets and vct pads back in the 60’s. My evening/Saturday job was to keep his detergent to supply mixed and ready.
What I remember (and HATED!) was his first portable extractor (we called them steam machines back then).
Now I had to bring him clean water and take away dirty water. Twice as much work for the same pay (nothing)
I hated his switch to “steam”
If only they had Crocs back then..
Corners and edges stole your youth...
back in 1988 , fresh outta my Mutual Fund hawking career Daze, I went to work for a janitor that used to shower feed soap on commercial carpet and charge huge money for carpet cleaningYea 175 and bonnet. Joey Picket, Bob Bonwell both were pushing us to try it in the mid 80's.
It looked ok but didn't make sense when HWE was so easy.
At one time we had 5 HILD 175'sOne of the earliest low moisture machines for me was an old used Hild 175 rpm machine, with a shampoo tank and an aluminum-backed Braun shampoo brush.
Started with rotary foam shampoo. At times I used a 175 and bonnet with Deep Action from Hillyard chemicals. Worked great if you could tolerate the fumes.
