Meter Maid
The Undetective
- Nov 29, 2017
- 3,868
- Name
- Chris
I agree. Wondered why my chem injection stopped working. Screen filter was clogged with the stuff. I even mixed it on the light side.Dissolves bad
1/3 of a tub left. Have to scrape with the scoop a lot to loosen it up.Seems to get hard once you open the jug
Shouldn't need to do that. It should be soluble.use a cordless drill with paint mixer in hot water
Absent minded carpet cleaners.Had a nasty today i wanted to try dry slurry on but i left it at the house. The Prochem acid rinse i like better than the powder.
Willy is that you using a fake profile?I mixed a teaspoon in a glass of hot water and let it sit for a few minutes.
Easy to see the powder at the bottom of the glass.
Try stirring.I mixed a teaspoon in a glass of hot water and let it sit for a few minutes.
Why? It’s supposed to dissolve in water.Try stirring.
So, I’m supposed to go from pouring 32 oz in my 5 gallon jug and working, to stirring this in hot water before pouring it in my 5 gallon jug?
So what’s the benefit of this powdered rinse then?if you want it to be dissolved...
Looks to beAre those pieces of your screen filter laying on the bottom of the jug?
I’ve tried 4 different rinses and all of them want 32 oz in the 5 gallon jug.That's a great way to create a repeat clientele...
Most rinses I’ve seen recommend 32 oz in the 5 gallon jug.
You are more than just a little stupid. Do you stir your coffee when you put sugar in it?Why? It’s supposed to dissolve in water.
Well... I guess I was told to use a rinse.like most juices, price per RTU gal is a little less
also take up less room on shelves
can you tell me why you think acid rinse is necessary?
can you tell any difference when you use it ?
Or do you use it 'cause "everyone says so" ?
Hold on, asshole.You are more than just a little stupid. Do you stir your coffee when you put sugar in it?
Doesn’t an acid rinse help pull out soap residue from household products and shitty carpet cleaners?
Doesn’t an acid rinse help prevent wicking?
That was very helpful and I thank you.lemmie help you with mixing powders
do you have short piece of solution line?
If not, get one.
(or use your sol line)
When mixing powders, use hot water from the TM, while using the hose to stir while filling
fill your jug while bleeding off hot water at shut down.
