Almost burned down my van
On a job this morning. My oldest came with me to help. I’m busy cleaning in the house and my son runs in and says “Daddy, the van is smoking!”
I immediately drop my wand and run out. Sure enough, smoke was bellowing out the back of the van. I immediately shut down the 870 and then took a deep breath and jumped in the back to see what was going on.
I discovered that somehow a superzorb bonnet fell into the back of the tm and came to rest on the exhaust manifold. I pulled it out and the edge was on fire. I was probably seconds away from losing everything. Glad my son was with me today.
I had a similar cotton pad burn to a crisp on an exposed HX almost 20 years ago. Fortunately there was nothing else flammable nearby, because the fire was out before we noticed it.
On a job this morning. My oldest came with me to help. I’m busy cleaning in the house and my so. Rins in and says “Daddy, the van is smoking!”
I’m glad you and your son are ok. The machine and truck too...but they are secondary.
Van and truck mount fires were more common in the past when more truck mounts used secondary fuels and dry solvent cleaners and deodorizers were more often carried in vans.
Fire extinguishers are a good to keep in the truck.
Guys sucked up a rag while cleaning out the tank...
Fat Mike
Mike G
The first thing I thought Of when I read the title was “again!”
You still have that other Tm?
Wow, Damon. And by the way, I suggest you invert your dry chemical extinguisher and shake it until you can feel the powder slosh inside, like a liquid. Whack it with a rubber mallet if necessary.
i used to do this to every dry chem extinguisher on my ships, every month. You have to prevent the chemical from compacting, or it will not blow out the nozzle. Worse, a little might blow out and the extinguisher fizzles out. Do it today.
Fat Mike
Mike G
That’s good to know. Scary to think mine at the shop would fizzle
Reactions: Old Coastie
Fat Mike
Mike G
View attachment 100805Expensive mistake. My 870 almost went up in smoke.
I had a battery blow up on my once. I knew to not hit the posts and I wasn’t. All I did was twist the terminal on a friends car and they probably been beating on the thing and guess the post was loose and exploded on me. Thank God I was injured but it was loud like a shotgun blast
Reactions: JS41035
Steve Lawrence
Glad your son was with you, too. I almost burnt a van up a long time ago when I had a propane heater for portable equipment. Left it on when it was not in use. Yikes!
  • Wow
Steve Lawrence
Hey Damon, is there a way to prevent that from happening again? (Perhaps a cage or something so your exhaust manifold can't burn something up as easily.)
IT was a 1 in a million thing. I think I may have thrown a pad on top of my machine and while driving around it slid down. I just need to never put anything up there again.
