How much water are you using?
Swani
Today I cleaned around 1500 sq ft of carpet with my 6 jet, 9 flow at 600psi and used around 55 gal. Of water. Is this close to the amount of water you guys are using?
roro
Ross Craig
You are using about 22% more water than the guru in an area that's almost 50% higher in humidity than his??? I'd be reducing my jet size and turning down my pressure a lot.
roro
You would notice those things if you use 50%
capacity in your first small house Moron!
Reactions: hogjowl
Swani
Id probably be at about 85-95 gallons at 400 psi and 6 flo - same proceedure except with a CRB. Maybe Im doing something wrong.
What machine are you running? This was wide open areas with no furniture. There was no idle time so the machine never bypassed water.
