Screw the TP, I'm ready for the apocalypse!!
Ann Arbor
Steve Lawrence
Hey Mike, my son really liked the fragrance of Prochem All Fiber Rinse when he was cleaning furniture with Jim Pemberton at Ronald McDonald house in Nashville (about a day before the crazy tornado.). He wants to get our Butler injection systems working (OMG) so we can run that stuff, but we have been using plain, softened, slightly acidic water to rinse carpets for a long time and we have liked the results. It's his business, now. He's probably better at this stuff anyway!
Less residue than rinsing with water!
New All Fiber Rinse will completely change how you look at extraction rinses. It cleans BETTER than your favorite go-to detergent rinse yet leaves less residue than even a water rinse.
If you already use All Fiber Rinse (bottle) and All Fiber Deep Clean, here’s how NEW All Fiber Rinse is DIFFERENT - it applies unique technology that cleans better. New All Fiber Rinse can even attract and remove soils and residues from previous cleanings – a breakthrough unmatched by any other formulations to date.
One of a kind
New All Fiber Rinse uses next-generation chemistry - Residue Release Technology! It has a strong attraction to the soils and minerals that cling to carpet fibers, but it ISN’T attracted to the fiber itself. PLUS, it binds the soils and minerals (called agglomeration) - even tap water minerals – for easy removal and a residue-free feel that’s super soft. And it stays cleaner because less residue results in less resoiling. Plus, it has a stable 4.2-4.5 pH, and a light, customer-pleasing fragrance compared to other acid rinses.
This is an industry-first, high-performance rinse!
You will be astounded to see how our hydra-coating technology allows All Fiber Rinse powder to dissolve quickly and completely - and stay clear - in both hot AND cold water. It also doesn't clog filters and jets like some powders do. All Fiber Rinse has other great benefits, too - it’s non-corrosive to copper, brass, and aluminum, helps prevent scaling and mineral build up and its cost-effective powder formulation makes up to 30 gallons of RTU solution.
can someone do a test with the new all fiber rinse on a dirty carpet with no pre spray just to see what happens?
