- Apr 19, 2007
- 11,013
- Name
- Ofer Kolton
Thank you Scott. Good job. I think you may have managed to confuse us even more
Jokes aside, I think Interlink has a problem communicating clearly with the fold, as to what works for what. Trust me on this one: If people get confused, they just won't buy it. Or go with the slick sales person (no names mentioned) that may offer simplicity or worse: Telling them what they want to hear, which is not necessarily what's right. See some previous posts. It may hurt your sales.
I very much prefer to make educated (knowledge based) decisions, which in my opinion you are not providing in a clear and easy to understand manner. This is meant as feedback to help you and not a put down.
So:
So:
- Advanced with Teflon is best for solution (not acid) dyed carpet as it does not contain acid dye blockers which are not needed. I assume it is cheaper alternative to Maxim advanced but for those carpets will offer the same protection.
- Advanced with Teflon can also be used for upholstery that does not need acid dye resistance. It is cheaper than Maxim for Upholstery. If used on upholstery it will leave it more wet. But will offer the same protection?
- Maxim Advanced for upholstery works better for natural fiber. Is it just about faster drying and the flexible polymer, or is there more to it? However, when used on upholstery, will it give any better protection than Maxim Advanced?
- Maxim Advanced for Wool is the same as Maxim Advanced, only more concentrated? Can we carry only Maxim advanced and dilute it when applying to Nylon? Can you use the same logic and also apply to upholstery that does not require as fast drying?
