Auction Rotovac Sheardry Upholstery Tool
Up for grabs is a new Shear Dry hand tool
    Dual Direction Spray Bar Centered Between Two Vacuum Slots
    Fiberglass Reinforced Composite Body - Strong & Lightweight
    Vac Slots Close to the Front & Side for Better Edge & Corner Cleaning
    Solution Holes Are Only 1/16" Apart for Streak Free Cleaning
    Thin Side Profile for Better Reach
    10' Hide-a-Hose With In-Line Filter
    Super Comfortable Design for Less Hand Fatigue
    Easily Replaceable Cleaning Head - Only $19.95
Retail value is $395
Auction starting price-$250 w/ $5.oo minimum increment
Free shipping to the L48
Auction ends 3/8/17
It's a fair deal at the above price, just zippy tie the needle valve assembly to the vacuum hose to minimize flexing on that point of the hose.
Somebody at MF told me they plugged up/blocked off the back row of holes. I think I'll try doing that too..
Your going to defeat the cleaning zones effectiveness.
I'm telling you Marty is on today.
Very entertaining. Must have ate some funny food or something.
Reactions: Mark Saiger
GeeeAus
Grant Baverstock
It's a great tool and well worth winning. Very effective on urine contamination in upholstery and some mattresses too. The solution comes out really hot because the pressure is so gentle. Like many well specced tools it has a flow control tap at the QD connector. Being a trigger tool with continuous flow it won't smash your solution tank prematurely making to play water boy/girl if you do a lock in job or work tandem TM and porty upholstery projects.
Tool picks up heavy soapy deposits introduced by things like DIY spot removers with minimal repeat passing and minimal foam crowding in your vacuum line because it has no jets to agitate surfactants into foam. Very handy cleaning up after the consumer.
Tool works well for advanced stain removal processes because the stream of solution water from the tool communicates heat to the carpet VERY fast and opens dye sites permitting better access. Chemical bleaches are exhausted quickly helping ensure no colour loss beyond the removal result.
In principle I like the onboard vacuum relief though I have in all honesty never used it.
Of my three upholstery tools it's my most used at the present.
Disclosure....
I expressed interest in testing a ShearDry and was sent one at no cost. I have been allowed to retain the tool.
Hope somebody who likes doing upholstery wins it; it's very capable and once mastered will make you lots of money. The mouth of the tool is quickly and cheaply replaceable so it should be easy to keep in service.
I believe Mr. Saiger even has such a beast. A sure sign of a pedigree. :headbang:
