I think my Little Giant is too close to my C4
the oil valve cover has gotten so out of shape the even with a safety wire and thick teflon tape around the cap threads, I have oil leaking out from under the yellow cap once the unit is hot.
you can see how close in this photo..
Les sent me a new new valve cover but I'm thinking I better create a heat shield to prevent further warping.
Any one else have this issue?
you've dealt with this very issue or are you just trying to sound actually experienced in something for once?
KevinD
Kevin Dumas
If it is getting hot enough to warp things I would be more concerned with the fuel pump and lines right next to it.
but than again, I'm guess that the cover is being warped from the heat, it could just be faulty. its darn thick plastic.
KevinD
Kevin Dumas
I've seen more Kohler fill caps leak than not.
Just recently had a guy come in with a engine knock.
Brand new engine the fill cap was not seating correctly. (piss poor design)
My own 38hp Kohler has the biggest pos fill cap design on it and it also had factory defects in the valve cover oring.
So I wouldn't be suprised to see a defective part.
Shane T
Shane Tiegs
Even though your LG is close I doubt that it is the cause of the cap warping. More than likely it's the heat from the motor itself and maybe the cap it made of the wrong material. That plastic igniter your have attached to the LG seems to take the heat.
You could try some tin or other flashing type metal between the motor and the lg as a heat shield?
BradFenstermaker
Mike like lockhart said get some sheetmetal from a race shop nearby. Glue some insulation on it. Make a divider. My silencer box in the Vortex was barely warm and made like this.
Not sure what insulation they used but the fuzzy side was facing the silencer.I dont think the heater is the main cause though. My #3 doesn't get that hot.
new cap/cover.
Did I hear that some glass chined pussy from another forum thinks this is a Judson bashing thread?
If I somehow over looked the fact that Judson owns Kholer or is responsible for Greenie's decision for placing the heater so close to the motor than I suppose it is :oldrolleyes:
I in no way hold Les, Dick or Jud responsible for this turn of minor events.
B
Becker
Oil manifold.. LOL
I'm converting a unit from heat Exchange to Propane.. Winter took it tole on the heat exchanger. :(
Spokane get cold. Sub zero, older van with air leaks.
On this unit I'm looking forward to propane. I'll be sure to mount the giant back a bit.
R
Royal Man
I walled off my little giant on three sides for safety reasons. I've heard of carpet pad or some other crap shifting and causing a fire. I also elevated mine. If there is a leak, propane is heavier than air and it will flow out the door. Also, put a mirror under it, incase I need to light it with a bar b q lighter.
Kevin B
Kevin Bunce
Oil manifold.. LOL
I thought you moved back to the wet side?
I would go with a kero Northstar if I went burner on a TM.
M
Mike Draper
no prob's with mine. I would say it is from engine heat and a bad part as well. the LG doesn't create much heat to the side. Mine in within half inch of carpet and it has never melted or deformed the carpet. However, at the top of my LG I do hae a heat sheield that protects the wall.
It's awful thick plastic on the valve cover and the cap has never turned this hard so I'm going to go with it being a faulty cover.
I'm going to replace it today while Harper and Foster sit on Allsixofus and cry to the world about how I'm Judson bashing.
btw, Marty thinks he has the exact same issue on his Kohler Command 27
KevinD
Kevin Dumas
That's the engine (27hp) that was brought to me that the fill cap was not sealing correctly.
From sealed to unsealed was less than a 1/4" turn and literally took no effort to tighten it against the oring.
Reactions: hogjowl
Exactly.
This new cover takes considerable effort to close the cap.
I believe this motor is not used on the C4 anymore.
Kevin B
Kevin Bunce
Why a polymer cover I wonder? you could buy a plastic printer and make your own lol
Louis
Louis
Off the subject , but what kind of hose is that running the propane to your lg heater?
Thank You
Louis
Louis
I need to get some hose to run from my belly tank to the LG and IDK what kind of hose to buy.
Louis
Louis
I guess I will save my old valve cover if I replace my motor, The old style goes on like screw top.
KevinD
Kevin Dumas
I just go to the local propane shop.
They give me the hose I need rated for propane (cut it to fit) and special fittings you put on with two wrenches.
search for something like your'e talking about and old found some strange soft porn
clean image
Carl Maddock
Mike, search engines are pretty smart now a days, they use your past search criteria to help future searches
Might wanna get a seperate compute for that soft stuff
