WIll this or similar actually stop the dreaded Kohler rear seal leak?
just replace the seal...
Swani
Out of 111, it worked for 70, and 41 it did not.
My diesel started leaking and I tried adding the Lucas additive for oil leaks and it didn't work.
Don’t overlook the poor quality of manufactured goods these days. I hope it works. I’ve got a zero turn mower with a Briggs that I’ve got to fix before spring. Had it professionally fixed twice before.
Would the equivalent Honda engine be able to replace that motor?
Willy P
Willy P
All you'll do is gum up your system. Speaking from experience, none of the "liquid repair" stuff lives up to the hype and can make it worse. Besides, you're a pad lad now.
