What's up with lockdown?
Dwain Ray
"Jesus said to him, “If I want him to remain until I come, what is that to you? You follow Me!” Therefore this saying went out among the brethren that that disciple would not die; yet Jesus did not say to him that he would not die, but only, “If I want him to remain until I come, what is that to you?”"
I only said I move my arms very little!!! 😄 Although that is a bit of an exaggeration, but I do try to move them minimally by emphasizing body movement over arm movement. So I don't become a deformed elderly carpet cleaning in years to come 😬
What do you think of my technique? It's probably not great. Please help a brother out..
View: https://youtube.com/shorts/s5iOErfOaR4?si=iyx_BVn1ztFphc5x
If you'd getta drag wand you could forget about all this crap and just drag it. No glides to wear no vacuum loss and really dries quite well , and theres a size for just about any type or style of cleaning
  • Wow
Reactions: Bryce C
Looks great Bryce!
View: https://www.youtube.com/watch?v=7Y_HBURW8OM
I don't know enough to get into the fray and obviously It's rare, but would a Rotovac be worth the nasties and this carpet occasionally?
We have the RotoVac 360iBH for the nastiest of carpets- But You MUST clean the entire area with the wand again. This is because the 360i will leave behind dirty water in the carpet.
We use a CRB for moderate soiled carpets because 1 crew member and be scrubbing while the other is cleaning.
Reactions: Bryce C
Correct.
I talk to 1000's of cleaners around the world to come up with my findings.
The best customers keep cleaners that are trustworthy, friendly, comfortable to be around, and multi-surface capable.
Dry times, results only we notice and price don't really matter.
Of course many of us don't have enough of the best customers so then we have to make end meet with the price conscience or commercial work or the neurotic homeowner where everything is flipped upside down.
If we find ourselves 30+ years into this career and we're still dealing with customers that obsess over dry times and cost, we've made some huge mistakes along the way...
"How long will the carpets take to dry?": seems to be the 2nd most asked question after how much will it cost.
Man! when we had those fires and RH was 16%-- the carpets dried instantly!
Can more people lose their homes so I can clean carpets faster?:eekk:🤣
  • Haha
Reactions: Jim Pemberton
Bryce C
DFW
Bryce
I'm aware of that, I have one. Dang, I have everything😉
Dwain Ray
Right-o good to know, thanks Mike!
Those things look sweet Dwain-o. Are there any good modern makes of drag wands?
Not to my knowledge. Ive used drag wands since my beginning. The 16" (middle one) is the tool used on every job . Because it's way lighter, the 12" (front) is what i use one area rugs and in tiny homes,5th wheels and large rvs Because its more maneuverable. The big 24" has the same weight as the 16 but 2more jets. To tell the truth i just got it in a deal i found on Facebook and don't really have must experience with it.and theres a company in Utah that goes around the country cleaning Mormon churches and uses them exclusively. Im trying to find them and see if there intrested in buying the one i have. I first clean with a rotary then rinse and dry with a drag wand one of the nice things about themis they go right to the edges and corners (no edging) also they dry really well so well that if you were to stop and continue spraying they will pickup virtually all the water they put down . And the 2' clear tube gives you a easy clear view to monitor your progress i own several of the 16" but only one each of the 12&24
20170507_152227.jpg 20180618_172747.jpg 20180618_174242.jpg 20180327_013229.jpg 20180327_020709.jpg 20171118_084625.jpg
Reactions: frank fratto
Zipper. The difference, it cleans front and back. It would be cumbersome in a house I think, unless empty which I've done.
Dwain Ray
How long does it take to clean that restaurant?
That was a larger Dennys that only got cleaned when corporate got down on them. It took about4½hours with a wait for them to close one side and open the other they were open 24hrs. Its probability the worst ive done. The last person that did it left so much soap that i went thru a whole small bucket of defoamer
20180326_223026.jpg 20180327_005337.jpg 20180327_002312.jpg 20180326_230300.jpg 20180326_231731.jpg
Reactions: they live
DwainO......I love it!!!!
Drag wands are GREAT if you only wanna clean one side of the fiber!
Dwain Ray
I don't just clean with the drag wand. I first lay down prespray then with my machine injecting emulsifier i throughly clean and dry the carpet with an rx20. After that i switch the machine to a acid rinse and completely redo the carpet with a drag wand. So i first clean n dry then i rinse n dry. "Two timen Dwaino cleans every carpet two times". Area rugs get only dragged because the rotary just wads um up but i drag um twice generally speaking most of the time in two different directions
20230902_110614.jpg 20230902_113914.jpg 20230926_112346.jpg 20230926_113804.jpg 20240106_122223.jpg 20240106_124323.jpg
they live
Steve
View attachment 133914 View attachment 133915 View attachment 133916 View attachment 133917 View attachment 133918
Thats a lot of work. It sure looks good.
