Vac. question
phenning
2-2 stage vacs in parallel or 2-3 stage vacs in parallel. What is this difference between the two configurations? Does it help with drying, length of hose runs, or is there little noticable difference in performance?
That is like saying V-6 or V-8, which gives more horsepower if all other variables are equal?
Yes bigger is better in this example....but, like all rules, there is an exception.
A 2 stage 5.7" vac motor might have 100cfm and 105" of water lift and pull 9amps on start up.
A 3 stage 5.7" vac motor might have the same 100cfm, but be rated at 130" of water lift and 11amps on start up.
Since both are plumbed in "air-parallel" in your example, you would have Double the cfm (200) and the Same waterlift as a SINGLE vac motor. 200cfm and 130" lift is nothing to sneeze at, and 200cfm and 105" is still very effective on shorter hose runs, especially if the hose is larger, like 2" truckmount hose.
Besides the obvious "size" issue (a 3 stage is taller) you have Amperage issues to contend with, there might be a reason a particular manufacturer used a small and lower amp draw vac in a particular set up.
Dallas, Texas USA
phenning;
That is a poor design with two 2-stage vacs in parallel.
Who's machine is that ??
Two 3-stage vacs are better (series or parallel), since they have more lift & air watts.
Larry
Larry, why give him confusing and erroneous information.
If someone wants to use two 2 stage vacs, I don't care, it's their design, if it's a single cord machine, that may be all the amperage they have avail. on a single 20 amp circuit.
And just for the record, a 105" waterlift and 200 cfm configuration is very effective on 25' (or even 50' of 2" hose) with 2" plumbing, the low lift isn't neary as important on a short hose run as the larger hose is very efficient, and there is very little "loss" involved.
I can see that Greenie is expanding his expertise into the new rage that is portables.
Just post a disclaimer that you are not responsible if your advice BLOWS up and injures someone.
Greenie Disclaimer: I am not responsible if this advice BLOWS up and injures someone.
Thank you.
