turmeric removal
Becker
Snohomish, WA
Becker
Good luck. What fiber? I see a lot of those type of stains up here. It's what make mustard yellow. And wAs only used to appeal to kids.
I see it around my clients area of worship.
sodium percabonate mixed hot very concentrated worked for me.
It took about 30 minutes for the stain to go away.
Becker
Snohomish, WA
Becker
What fiber Daniel? Hows fishing?
Mounting my new bow motor and going after Small Mouth, Rainbows, and Walleye Sunday, then all weekend the following.
What happen, you spend time in the clink?
C&S
meadville,pa
Scott
Ive tried a ton of stuff, used stain zone from bridgepoint. It didn't touch it.
Sent from my HTC6435LVW using Tapatalk
Shelbyville TN
As Larry says, the UV light is important part of the process. We have had success with StainZONE and the uV light. You will get best results if the carpet is not too badly abraded and if it has been protected in the last year. It will take a lot of patience to remove turmeric from old worn carpet.
