RX-20 What type of glide?
kmdineen
Kevin Dineen
The hole glides on my RX 20 (full slot vacuum) are worn down pretty good. I just switched over to 02 jets, 5 for a 10 flow so I am getting a good flush. I use the RX on commercial carpet only and get good dry times with the hole glides. I am thinking of trying slots or hybrid for my next set of glides to get better agitation and pick up more embedded sand and crud. What would you recommend?
scott schulte
Stick with the holes, just make sure nobody sees you using them or the ChemWho police might come getch ya!
FastEddie
With rotary jet extraction, I would definately go with slots. You won't believe how much more crap is sucked out of the carpet. Believe me, the proof is in the filter.
Jester
Is there a when going from a hole glide to a slot or a hybrid is there a big difference in dry times or is it not very noticeable. all I have used is holed wand glides.
thanks
