Right On !!!! The most Wide Open TruckMount !!!
The new C-4
Nice machine for sure, BUT
If you are going to build a real money making machine Les, it needs more power (suction) to effectively run two tools and dual pressure regulators or possibly two pumps (not as important as the suction). High pressure would be nice too.
Why can't you use a larger motor like the Nissan and build a machine with larger blower plumbed right?
I would love to demo one.
dgargan
clean and simple. Doesn't get any better than that. And you can find 99% of the replacement parts locally
vincent
O'Fallon, MO
Vincent Sapp
What the hell?
Just what level of mental retardation do you suffer from Daniel?
on lets say a scale of 1 to 10.
Have your mom help come up with the number
L
LGSTEAM
Sweet machine Les. Is the tank the same size as an TNT machine? I have an idea about turning my old TNT into a Beast like this one!!
ACE
Lawrence, KS
Mike Hughes
8) Looks like something I could work on without cussing.
What kind of vac relief is that?
Do side mounted engines stay as cool as front mounted engines?
vincent
O'Fallon, MO
Vincent Sapp
Waldo said:
Why do you need one?
well, one for thing, its where the rinse goes to mix with the fresh water and then exits out through the solution hose. And, I don't know the rest, someone help me, I've fallen down.
Bob Foster
LOL!!!
so it can utilize a chem siphon feed.
the pump has to "suck" from the water box .
If it was forced into the pump by direct water hose hook up, it wouldn't create a "vacuum" to draw chem from the chem jug
Plus, they're a good idea if the pump and tool flow can out pace the flow on some water supplies .
With a normal duty cycle of wanding/dry strokes, the water box acts as reservoir to draw from
Po Dan'l ..I didn't have the heart to say anything ..cause I genuinely like the Little Cowboy
But i was thinking the same thing when I read his post :lol:
:lol:
It's a great single wand machine.
And yea I would love to have a super suck machine with dual pressure regulators and not spend 100k.
Benton KY USA
You can add a second pressure regulator to any machine.
The primary (factory) unit set at the higher pressure, and the second one, fed from the output of the first one, at a lower pressure.
Utah
:lol:
uhhhhh you dual with your machine right????
SAMEEEEEEEEEE BLOWER.....there danny boy..
with out the restrictions the prochems have....
now thats not to say i wouldnt love to put my 4cyl nissan on that there frame with a 56 or 59...or on the older (drapes) frame
Shane T
Waukesha, WI
Shane Tiegs
Nice! I assume its a slightly lower cost C4 than the original? No Bayco valve or silencer. Is that the Roots 59? Might loud at max rpm?
Bob Savage
Dayton, Ohio
Bob Savage
That C4 has all the vacuum you would ever need/want for single or dual wand cleaning.
Coupled with a 4HT, it also has all the heat you would need.
Any more questions?
Walt
The side mounted engine fan blows the air past the heater and out the back door. It stays surprisingly cool for a machine that generates so much heat.
It's kind of genius really.
steve g
herriman, UT
steve garrett
how big of a blower is that?? speaking of water boxes last place I worked there was a tech that noone liked so another one of the guys working there decided to take a leak in the water box. :lol: :lol:
