In a new radio commercial I want to add a reference to our website with a list of helpful tips to keeping your home dry.
Can you think of any others I may have missed?
Dry Home Tips
Rain Gutters: Check your gutters for obstructions, leafs and pine needles can cause water to backup the roof and go inside the attic space and walls.
Down Spouts: Make sure are carrying water away from the home and as far from the foundation as possible.
Sump Pumps: You might also check the mechanisms on your if you have one and make sure its operating correctly.
Outside drains: Clear drain grate of any of leafs and debris that could cause water intrusion
Window Wells: Make sure they are covered and that the soil level around them carries the water away from the home.
Dry Home Tips
