Rex,
Sorry man I didnt think I was being judgemental. I was just chatting. You guys can use whatever, I dont care.
You are right these products have been in use for decades and they are still on the shelf, well so are cigarettes, they just can under heavier scrutiny the past 20 years. This whole green thing that is going on is still in its infancy. You can compare it to our use of oil. We know it bad to use but we use it, Why? Because what else are we going to use. Well greener cars and trucks are 5-10 or so years away from being mass producted to replace the gas engines, same with green cleaning products.
We just need to find something that is equal or better to replace the harsh chemicals currently being used. Look goverment building are requiring green product to be used. BOK is great stuff, other green products are great too.
Look at EGBE ("Butyl") Used in Cleaners, Degreasers and Wax Strippers
Ethylene glycol monobutyl ether (EGBE) is an ether derivative of ethylene glycol and butyl alcohol. It has a number of synonyms including: 2-butoxyethanol; n-butoxyethanol; glycol ether EB; and butyl oxitol. It is frequently referred to as "butyl."
THe CDC said in a recommendation, "The results of studies in animals have clearly demonstrated (EGBE) dose-related adverse effects on the central nervous system, the hematopoietic tissues, the blood, the kidneys, and the liver. Limited data from humans also indicate the risk of adverse effects of the central nervous and hematopoietic tissues, respiratory distress, change in motor activity, lungs, the blood and the kidneys." EGBE also exhibited strong teratogenic effects like the inerfering with the development of a fetus and causing birth defects.
Its no secret these type of chemicals are bad, but the chemical companies will still sell it to you because people will buy it. Until they are not able to anymore, chemicals get pulled off the shelf every year, there will be a day when butyl will no longer be used because p[eople realize the health risk and because of the green alternative. Some day not today.
Again I am not judging anyone for using whatever chemicals you use, just be safe out there.
