Water? I worry more about heat. Larry- Are you one of those guys with water pouring out of their vans while they're cleaning?Do you think the full headliner will hold up to the moisture in the van?
Never seen it left in a carpet van before.
Sent from my iPhone using Tapatalk while Peeing into the vacuum hose
Pretty sure I'll go with a fork lift.. Like above, I don't think I'll have the clearance for a cherry picker.
Hoping to have it installed by the weekend.
At the latest my goal is to do my 1st job with it by oct 7th.
I made a TM stand with adjustable legs and heavy duty wheels just a bit bigger than a 405 footprint. Makes it pretty easy to remove and install the machine for one man.
Hate to get one on the floor, hard to work on, and a cherry picker is a tight fit many times.
I don't see many Alum Liner s like Steamway sold anymore I still have one, 20 years old, keeps liquids contained. I thought they had some kind of wheel system under their truck mounts for easy service too.
hey Jim Martin, can you make a video of your van setup when you get a chance? did you use marine plywood wood too, and carpet? or did you have a spray liner put on?
