?????I've used the upholstery tool hooked to a pump up sprayer, worked ok.
Using boosted OMS in a special situation.?????
Pictures?? Video? Why?
Mytee often gets a bad rap here but some of their machines are quite well designed. Just have to modify them a little.Yes but it's from mytee, so I'll just stop there and not waste your time.![]()
yeah cause none here like to modify anything.. all are using the original wands, filters and hoses that came standardMytee often gets a bad rap here but some of their machines are quite well designed. Just have to modify them a little.
I just like the speedster configuration. Large rear wheels, 2-3stages in parallel, your choice of pump. Just had to modify it from a 1 cord 20 amp machine to a 2 cord machine. Most of the time in Canada, we don't have 20 amp circuits. Now that I have the 2 cords, it gives me the freedom to put larger vac motors and pumps. I believe you can custom order a new machine from them. Just have to know what you want and why.yeah cause none here like to modify anything.. all are using the original wands, filters and hoses that came standard![]()
Not sure how that make any difference. You have 220 volts over there don't you?Yeah Im looking at there porty range (as much as I hate portys) 2 corded machines are illegal here based on if they short on the inside the other plug could potentially become live.. but I've never seen any porty police![]()
230/240 volts. You can get around the law by putting locking castors on because then its fixed plant not portableNot sure how that make any difference. You have 220 volts over there don't you?
The new Mytee have locking casters. With a single cord 220 volt machine you can have a 500 psi pump and 2 3-stage vacuums. With 2 cords, you can add a fairly powerful heater. We're stuck with 120 volt 15 amp circuits here.230/240 volts. You can get around the law by putting locking castors on because then its fixed plant not portable![]()
