hybrid or holed?
SRI Cleaning
Anthony Firmani
I have an evolution truckmount and I want to switch to a greenglide. I dont have much experience with hybrid or holed glides. Which one should I get? i was hoping to get an easier push that the slot glide that comes with the wand. Do the holed ones clog alot? i do alot of rentals but i still usually vac them, just quickly. Would I be better off with the hybrid? Does the hybrid push easier than the slotted glide? any disadvantages to either?
Brian R
Brian Robison
I used to use the slotted and now use the hybrid. I like the Hybrid a lot better. Easier to push, dries the carpet even more and it still doesn't clog that much especially if you vac.
If you vac really well I would imagine the hole glide is even better.
I only have to pull my cuff off to get some bigger debri. I am happy with it.
One thing that I found with the slotted glide is after about a year or more the slots will open a little more... almost like a bowing effect. But that was a lot of using it.
All glides have to be sanded to keep the rounded edge every once in a while and you have to widdle downe the "little slots" to keep the airflow working ("on the slotted one anyway)
Chris Muetterties
Both !!
You can have the best of both worlds with both.
I own a hole glide for my greenhorn, and have a slot glide for my hydrahoe. Hole glide pushes way easy and dries really well. After a year using my hole glide I've only had 2-3 times that I had something in a hole. I vacuum all of my jobs so that may be the reason why I've had so few clogs. But keep in mind greenie sends a keychain with a metal rod the exact size to push through to unclog it. So I see it as a non issue since it takes all but 10 seconds to unclog it.
