HEY LES, THANKYOU!
N GA
BradFenstermaker
Les wanted to say thanks for the phone help and confidence boost on doing my own blower bearing repair.
52 dollars and about an 1.5 hrs and the blower is spinning again.
Greenie also a thanks to you for mentioning Les in my blower post.
Later
yeah, he posted about it (to run up his post count) but did the cheap ass send you a thank you card or a bottle of moonshine for saving him thousands?
Les and I talked last night.
You've been black listed.
You'll either have to keep kissing Steve Smith's ass for pre spray or buy from Taf.
Doug Cox
Delavan, WI
Doug Cox
Les was also nice enough to help me out with a blower isue and a shutdown issue this week, which I truly appreciate.Thanks Les.
N GA
BradFenstermaker
Marty you should atleast apologize to Les with a nice Country Ham, well they may like Sugar Cured.
You have blower trouble to? Glad it is fixed, Les saved me around $2500.
AshleyMckendree
Versailles ky
Ashley Mckendree
Leslie Judson Jones said:
Ashley, once you pull the endplate off the blower, you can use a punch to knock the bearings out of the housings.
LES
Thanks for the help Les! But witch one is the end plate?
I made a reference image using your blower photo, is it #1 or #2 on the image:
AshleyMckendree
Versailles ky
Ashley Mckendree
The endplate is # 1
Thanks.
I what I have is an old Sutorbilt #5 MF That spins freely, but has hardly ANY vacuum.
The main shaft can move about 2mm forward/backwards and I just figured the tolerances where all out of wack and the plates needed to be machined perfectly flat.
Or maybe the bearings are old and worn and allowing the lobes to move a little?
