Flex w Citrus Users
GCCLee
East TN
C. Lee
Pretty sure I am gonna order a Pail of this stuff along with a 5gal bucket a AFR today.
I still use O2 + S&G an Just finished placing a refill order, Its that time of year, gettin ready : )
However, I like to keep a variety on board and occasionally mix it up a little, using different products for different situations.
Is Flex w Citrus Crackhouse approved and do you use an Acid rinse or jus water?
Fort Worth , Texas
Yes Chris good stuff. If you are high flow the just fresh water rinse will work, but if you are running normal or low flow then yes it needs an acid to completely rinse out.
Reactions: J Scott W
Cleantechsk
western Canada
Dustin
Im sure you will like it.
This was my first resi test with it. Just started so probably 100 degree water @ half oz/gallon
Russ T.
Slater, IA
Russ Terhaar
I use it a lot. Similar set up to you, I think. 6 flow wand and PTO. I almost always use an acid rinse with deodorizer for a little wow factor. The ladies love a nice smelling scent that will linger for a bit. I've been using Spice Air and am switching to Spring Morning this week due to the change in season. Both products are from Bridgepoint and I get comments all the time on how great they smell. We build deodorizer into our standard pricing as an added value. It's very cheap when you just add a bit to your rinse.
The Clean Machine
Johnny
La-Z-Boy
Johnny
Why use Flex over BioBreak? I used several containers of Flex but got better results with BioBreak. Is it based on fiber type?
I keep BioBreak with Citrus on the truck, as well. BioBreak gets crazy foamy with the addition of sodium percarb. Flex with Citrus does not.
d'lim / citrus usually calms the sp storm. Maybe sp added to BioBreak attacks the the bios, like peroxide on a wound.
Scott?
what are you using to rinse 02??
once you try Flex side by side to the other stuff you're using....welp...never mind... you're a sharp dude, you'll figure it out I bet
BLewis
Lexington
Billy Lewis
I've gone through probably 15 buckets and only use softened water rinse with no problems. Add a little when tile cleaning and pressure washing as well.
GCCLee
East TN
C. Lee
good stuff...I only use a soft water rinse as well..........
Theres another $700!
Thanks alot you lil redneck : )
Got a coupon code anyone, jebus $350 for free sh : (
I like my Rinse!!!! When I wan it : )
FB7777
Flex with Citrus has been my main prespray since it came out
Welcome to the high ph dark side Chris :evil:
Reactions: GeeeAus
GCCLee
East TN
C. Lee
Dude, you aint never seen me boost nuthin : ) atomic outta the keg'd satisfy me jus peachy!
Really Dark Purple Huh ; )
GCCLee
East TN
C. Lee
We use S&G + O2 and our guys love it. I've personally used FLEX and have no real complaints.
You mister : )
I love S&G, just refilled for the spring : )
How does the Flex compare?
And does it have a distinctive odor?
S&G works wonderful, but ya gotta deodorize as it has no smell.
Trust me, i got my first call back because of it, on a empty apt too : (
GCCLee
East TN
C. Lee
S&G is a very good pre-spray, Chris
Flex has a citrus smell
do a side by side evaluation in a trashed empty's living room
Judge for yourself
Thats where I am torn.
Not sure one will out clean the other so it comes down to usage n smell.
Guess i better sample a jug before buyin a keg.
Can some one post up a scratch n sniff : )
Arizona
It will out clean it and it smells just fine........I use it daily...never have I had one of my old grumpy clients complain about it yet........
GCCLee
East TN
C. Lee
I'll take that to the Bank : )
Thanks Jim
GCCLee
East TN
C. Lee
Flex with citrasolve has a nice orange scent whilst being applied and cleaning yet does not have any smell once cleaned out of the carpet.
Thats some of the things I am looking at.
For faster bang downs on these apts, i don wunna walk back in to deodorize.
S&G
comes down to RTU cost as well.
S&G is very good, but the thimble full pr 137 gallons of water RTU is unrealistic
(yea I know I'm being a sarcastic sum'beoich)
But the point remains
Only one way you'll find out, Scooter
do side by side on same room, same traffic lane/soil level split in two.
Do it on a couple/three different carpets types and soil types too when/if possible ...then you'll "know" and not have to take anyone's word for it
now get to it and order some
do it
DO IT NOW!!!
GCCLee
East TN
C. Lee
do it
DO IT NOW!!!
If I end up in yur will when u keel over, a 45 sure would be nice : )
