Crushed hose
Colorado Springs
Brad Gouveia
I was doing a pet spot and flushing it out with my spot claw and it collapsed my hose. I was hoping it would pop back but no luck.
Can I fix this or do I need to cut it off?
How can I prevent it from collapsing my hose in the future?
Thanks
Shawn Abbey
Salem, OR
Shawn Abbey
That has happened to me on several occasions.....
It happens. Just cut it off and re install the cuff. All will be well. The probable cause can be many things, just make sure the hose is straight when used.
GCCLee
East TN
C. Lee
Something caused it to get weak right there, bending maybe?
Dan
Beaumont, Ca
Dan
Caused by bending and kinking in that area along woth the heat. Cut off and don't look back. Cheap hose does it a lot.
Jamesh921
Central Oklahoma
James
The only time I've seen that happen is when the hose got in front of the exhaust. The heat weakened the hose, which caused it to collapse
