Jul 22, 2009 #1 Jim Martin Supportive Member Joined Oct 7, 2006 Messages 10,878 Location Arizona Name Jim Martin will copper remove from carpet the same way as rust.....
Jul 22, 2009 #2 GeneMiller Member Joined Mar 24, 2009 Messages 3,541 Location Boca Raton Name gene miller Jim, I use rust remover to remove the green stain under a/c units all the time. If it's not green then I don't know. Gene
Jul 22, 2009 #3 Mike Draper Member Joined Jan 13, 2008 Messages 4,402 you could always use copper remover that is made for cleaning gun barrels.
Jul 22, 2009 #4 Jim Martin Supportive Member Joined Oct 7, 2006 Messages 10,878 Location Arizona Name Jim Martin GeneMiller said: Jim, I use rust remover to remove the green stain under a/c units all the time. If it's not green then I don't know. Gene Click to expand... yep it is green.....
Jul 23, 2009 #6 Jim Morrison Member Joined Oct 7, 2006 Messages 783 Location Canada Name jim A couple of weeks ago I was cleaning in a basement and ran into a green strip. There was a copper water line that was sweating a foot above the carpet. Ultrapac Renovate removed it.
