No Albert, that won't work. Typical 2 speeds are DC motors. You have an AC motor. For your's to work it would have had to have 2 windings one for each speed. They don't come like that. The 2 speeds are not that great because there is only 100 rpm difference between low and high. You have a 175 rpm. (10to1 ratio) Some floor machines have a 7 to 1 ratio and that would give you 275 rpm's. I think this is a better, more versatile machine, so enough to strip and faster to bonnet. The 275 is a transmission change only.
