Cat 5CP hi temp seals
Cleaning Professional
Wrong seals were put in now I need to put in Hi temp ones.
They list two
76536 STHT= Special PTFE High temp
or
31638 HT= High temp EPDM Alternative.
So which one is better or is there a clear choice.
Cleanco will not give out the info but maybe he will.
Must order thru one of their dist.
In my research I went to cleanco's website listing diagrams of the cat pump and noticed hi temp seals. It had no number other than their code. So went on the cat pump website and under the 5cp looked down to the listing of seals. And found the number of the seals listed on my dultmeiers invoice. They were not hi temp. So I got the number off of the cat website for their hi temp 31638 hi temp seals.
Many thanks to all those who tried to help. Chris at Cleanco confirmed the right cat pump seal number. And a thanks out to Chan at TSC for his help. Jim Martin and a few others as well. Marty tried also.
I just wish part numbers were available instead of having to take it to a distributor so they could get their share.
And that's all I got to say about that.
Doug Cox
Doug Cox
Never had a seal failure with the stock seals ever on my powerclean and that pump was in a hot environment.
Magic One
That's a lot of $ bacon for 6 bubble gum seals. Another example how we get ripped off. I could buy 30 baconators at Wendys
I'm looking at ElectroSUX portables as we speak
Courtney has The Chief
It’s what I woul buy if I ever went back to slide ins
Reactions: DAT
