STEAM CLEANING EQUIPMENT
We provide a portable self-contained electric powered cleaning system. Our equipment has electric heating elements and a dual electric vacuum pump. Our portable equipment is outfitted with a strong spray pump that injects a high temperature rinsing agent into the carpet or upholstery without causing any damage.
Our choice to use a self-contained unit provides consistent high temperature steam at the carpet for the most effective and efficient injection system. Our self-contained unit also provides the most efficient vacuum power for the carpet optimized to a degree to achieve maximum cleaning performance without causing any damage to the carpet, sub-flooring or upholstery. It is not practicable to employ strong “jet engine” suction. The suction, or vacuum has to be regulated and optimized to achieve maximum cleaning without causing damage.
Our self-contained unit also provides the best and safest spraying system. High pressures in the spraying system can cause damage in the carpet and upholstery. Many are familiar with high-pressure washers, which can easily cut a tree in half. Not to mention carpet. The pressure in the electric portable carpet cleaning system is optimized to provide maximum cleaning with no damage to the carpet or upholstery.
In a van or truck mounted carpet cleaning system, the hot water or steam needs to travel on an average 50 meters. The motor cooling radiator functions pretty much the same way. In cooler months a substantial heat loss will occur through the 50-meter long pipe, which is exposed to outside ambient air. By the time the solution reaches the surface to be cleaned, the solution may be only lukewarm, resulting in huge loss of cleaning efficiency.
